separate interfaces of same network
Hi Guys,
I’m trying to separate, wired from wireless devices, both in the same network (192.168.14.0/24) using differents pools of ip.
Here what I’ve done:
eth2
  |--- vlan1 (vid: 20), address 192.168.14.1/24, dhcp server using pool "wired" (192.168.14.2-192.168.14.99)
  |--- vlan2 (vid: 30), address 192.168.14.100/24, dhcp server using pool "wireles" (192.168.14.101-192.168.14.149)
set in Network:
address: 192.168.14.0/24, gw: 192.168.14.1, dns: 192.168.14.1
in route list I have:
Dst.Address 192.168.14.0/24, gw: vlan1, vlan2, Pref.Source: 192.168.14.1
and it doesn’t work…
It only work, if I delete vlan1 and change the adress of vlan2 from 192.168.14.100/24 in 192.168.14.1/24 (ofc).
Any solution?
Thank you.
