Separate network trough Bridge
I would like to separate my physical port 5 ( Ethernet 5 ) from 2-4 ( LAN )
but allow it access to WAN ( Ethernet 1 )
I’m currently using the stock default configuration.
I went ( WebFig ) Bridge → Ports and disabled the interface Ether5 and indeed I didn’t get an DHCP IP.
( BTW what is the terminal command to reach Bridge → port ? )
So now I suppose I just top create a DHCP server for this interface.
That’s it ? are anyway they will be to reach one another ?
Thanks.
You have to remove that interface from bridge. Disabling it there just switches it off as a port in the bridge.
Not diving too deep into details:
  1. You can create another bridge, move that port to it and “clone” the current configuration to the new bridge but with different IPs and then forbid traffic between these bridges/IPs
  2. Reamove port from the current bridge and create/clone the new configuration just for that interface. There is almost the same amount work to do as with a bridge so I would choose option 1 as it let you move more interfaces back&forth in the future.
Thanks @BartoszP ,
But for a single physical interface, why create a Bridge !?
For future, if you decide that you want another inteface (e.g. WiFi) for that separated subnet than you are ready.
Edit:
BTW … the “Bridge” in the MT world, for most users, is the synonym of a “Switch” so treat it as separate device and remeber that the router manages them in one case as dual/tri/quadro/… “blade switch” and let the traffic flow from one to another by default.
Thanks ! @BartoszP very important reminder indeed !
so any MT Bridge ( switch ) can talk to the others !? by default ! and how prevent this ? (only by firewall rules !? or is there a more global option to disable it ? )
and are those MT Bridge are defaulted to communicate with single Interface (for example Ether5 here) ?
Treat bridge as a “virtual switch”. It could even has no real interfaces attached (look for loopback solutions for pre 7.something versions when the “lo” interface was introduced). Such a configuration gives you a lot of possibilities and flexibility in setup.
To prevent traffic you have to set firewall rules that block subnets to talk.
Depending on the device, it might be better to use VLAN configuration on a single bridge (or one bridge and separate ethernet interfaces without a bridge) instead of two bridges, as with two bridges you might lose hardware offloading on one of them.
You can see which kind of configuration is supported by which devices here:
And here:
Agreed, VLANs might be a better approach.
I have at home my WAN in a separate VLAN so I can easily pass it on via trunk to other devices for testing purposes.
Thank you @goscickiw
One Bridge and a separted Interface is what I wanted , but it seem it will not work with DHCP server… pff
THE Bible on setting up VLAN in ROS
No DHCP problems.
You should have reverted back the original configuration where ether2-5 was in the same bridge, then:
  • In the /interface/vlan table, add a vlan200 interface VLAN ID 200 (or any other number between 2-4094) with the bridge as parent interface.
  • In the /interface/bridge/port table set the PVID value of ether5 to 200 (and if you want, set frame-types=admit-only-untagged-and-priority-tagged instead of the default admit-all but it’s not mandatory for this use case).
  • In the /interface/bridge table turn on vlan-filtering=yes for the main bridge.
For recent versions of RouterOS 7, that’s all you need, no need to manually add/edit entries in /interface/bridge/vlan anymore.
Then go to IP → DHCP Server and run the DHCP Setup wizard for the newly added vlan200 interface. If you use the defconf firewall, maybe also add vlan200 to the LAN interface list.
