Separate network with access to the internet
I’m new to networking as well as Mikrotik configuration and would appreciate any help I can get. :slight_smile:
I am trying to create a separate subnet for my small homelab. Since I’m new to networking, trying to learn, but still not complicate things too much, the new network should have access to the main network and to the internet.
My main network is 192.168.0.0/24, the router/modem from my ISP takes care of wifi, dhcp and everything else. I connected one of the ports with my switch, which connects my main pc, TV.
The switch is also connected with Mikrotiik Hap ac2, which until now was being used as a WIFI access point (configured by using QuickSet).
The wan port is connected to the switch, ports 2-4 are used for computers from my small homelab.
However I’d like to separate the networks a bit and use the ethernet ports 2-4 for a different network, for example 172.31.0.0 or 192.168.1.0.
This network should have access to the internet.
I have managed to configure the Mikrotik to give those PCs an IP address with a predefined DNS server, however none of them can access the internet or any other computer in the household.
Here is a quick scheme of my setup:
This is my configuration:
# mar/07/2021 16:23:05 by RouterOS 6.47.7
# software id = Q6K6-I8T1
# model = RBD52G-5HacD2HnD
# serial number = C6140C325ACD
add admin-mac=48:8F:5A:A5:CF:86 auto-mac=no comment=defconf name=bridge
add name=bridge2-hypervisors
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge name=wlan1_2.4 ssid="You know the rules and so do I" \
    wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=slovenia disabled=no distance=indoors \
    installation=indoor mode=ap-bridge name=wlan2_5ghz ssid=\
    "You know the rules and so do I" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add interface=bridge name=defconf
/ip hotspot profile
add name=pool1-hypervisors ranges=172.31.0.2-172.31.0.250
add address-pool=pool1-hypervisors disabled=no interface=bridge2-hypervisors \
    name=dhcpserver-hyperv
add bridge=bridge2-hypervisors comment=defconf interface=ether2
add bridge=bridge2-hypervisors comment=defconf interface=ether3
add bridge=bridge2-hypervisors comment=defconf interface=ether4
add bridge=bridge2-hypervisors comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=wlan1_2.4
add bridge=bridge comment=defconf interface=wlan2_5ghz
add bridge=bridge interface=ether1
/interface detect-internet
set detect-interface-list=all
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wlan2_5ghz list=LAN
add interface=wlan1_2.4 list=LAN
add address=192.168.0.251/24 comment=defconf disabled=yes interface=ether2 \
    network=192.168.0.0
add address=172.31.0.1/24 interface=bridge2-hypervisors network=172.31.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
add address=172.31.0.0/24 dns-server=77.111.1.77,8.8.8.8 gateway=172.31.0.1
set allow-remote-requests=yes servers=77.111.1.77,8.8.8.8
/ip dns static
add address=192.168.0.251 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add distance=1 dst-address=192.168.0.0/24 gateway=bridge2-hypervisors
/system clock
set time-zone-name=Europe/Ljubljana
/tool mac-server
/tool mac-server mac-winbox
Ipconfig and traceroute:
tracert:
C:\WINDOWS\system32>tracert 8.8.8.8
Tracing route to dns.google [8.8.8.8]
over a maximum of 30 hops:
  1  172.31.0.1  reports: Destination net unreachable.
Trace complete.
ipconfig:
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Intel(R) Ethernet Connection (4) I219-V
   Physical Address. . . . . . . . . : 48-2A-E3-00-E8-87
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::8c8d:171a:9d5d:831%13(Preferred)
   IPv4 Address. . . . . . . . . . . : 172.31.0.249(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Sunday, March 7, 2021 4:13:28 PM
   Lease Expires . . . . . . . . . . : Sunday, March 7, 2021 4:23:28 PM
   Default Gateway . . . . . . . . . : 172.31.0.1
   DHCP Server . . . . . . . . . . . : 172.31.0.1
   DHCPv6 IAID . . . . . . . . . . . : 105392867
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-FC-31-76-48-2A-E3-00-E8-87
   DNS Servers . . . . . . . . . . . : 77.111.1.77
                                       8.8.8.8
   NetBIOS over Tcpip. . . . . . . . : Enabled
I’ve been folowing these tutorials/threads, however Im a bit lost now:
Can you try remove the static route that you have created?
Your /interface list members are set incorrectly. You have the individual Interfaces set as members, but the interfaces are slaved to a bridge, so you must use the bridges as the interface. As a result, your firewall filter rules are currently dropping your traffic. You should only need:
add interface=bridge list=WAN
Note: Once corrected, you will not be able to access the device from WAN network unless you edit the firewall rules.
Thank you both very much!
I will check and try to correct it in the following days.
