In the first, he used the hotspot in the Mikrootik
I have two lines, an internet line and an internal network line
I want the internal network line to use the line at all speed, and the Internet line I want to specify the speed users so that the speed of the internal network is not affected specifically, only the limitation is on the internet speed
It is not possible to understand what you mean.
Please
a. provide a network diagram and
b. provide the config
Thank you for your response
The Mikrotik distributes the IP 10.10.10.1
And the router 192.168.1.1 Connected to ether 1 In Mikrotik
There is cisco vbn 10.5.5.5 Connected to ether 2 In Mikrotik
Now any connection that comes to the vbn request is diverted to its path
All things are in the right direction but the problem
I want when I set the speed for the user to do it on the Internet without affecting the speed of the vbn
You limit speeds from devices to networks with Queues.
