Hi everyone,
I recently purchased a Chateau LTE6 and I have two ISPs: the main one is connected to ether5, while the secondary is a mobile SIM on lte1.
I wish to achieve the following:
- have a separate Wi-Fi that connects to the internet only through the secondary ISP (lte)
- use the secondary ISP as failover for the main connection (main Wi-Fi + ether1-4).
I tried to configure wifi3 to be on a separate bridge, with a separate address range (192.168.99.0/24) and create a route from that range to %lte1_digi, but it doesn’t seem to work. When I’m connected to wifi3, I get an IP from that range but I can’t connect to the internet.
For the failover, I don’t know how to create a rule that does the following: “if connected to the main ISP and some internet server like 8.8.8.8 doesn’t respond to ping for 5 seconds, switch to secondary ISP”.
Thank you!
This is my config so far (I censored mac addresses):
# 2024-04-06 10:45:46 by RouterOS 7.14.2
# software id = 25YV-CP45
# model = S53UG+5HaxD2HaxD&FG621-EA
# serial number =
add admin-mac=******** auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
add name=bridge_lte
set [ find default-name=ether2 ] name=ether2_lan
set [ find default-name=ether5 ] name=ether5_vodafone
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Romania .mode=ap .ssid=Tesla5 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Romania .mode=ap .ssid=Tesla disabled=no \
add channel.skip-dfs-channels=10min-cac configuration.mode=ap .ssid=Tesla_LTE \
disabled=no mac-address=7A:9A:18:CF:89:E5 master-interface=wifi2 name=\
wifi3 security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" name=lte1_digi \
sms-read=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool_lte ranges=192.168.99.10-192.168.99.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=dhcp_pool_lte interface=bridge_lte lease-time=10m name=dhcp1
/ip smb users
/routing table
add disabled=no fib name=rtab-1
add bridge=bridge comment=defconf interface=ether1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether2_lan internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
add bridge=bridge_lte interface=wifi3 internal-path-cost=10 path-cost=10
set udp-timeout=10s
add comment=defconf interface=lte1_digi list=WAN
add interface=ether5_vodafone list=WAN
add interface=wifi3 list=LAN
192.168.88.0
add address=192.168.99.1/24 interface=bridge_lte network=192.168.99.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.50 client-id=1:***** mac-address=\
***** server=defconf
add address=192.168.88.100 client-id=1:***** mac-address=\
192.168.88.1
add address=192.168.99.0/24 dns-server=192.168.99.1 gateway=192.168.99.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=hikvision dst-port=8000 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.88.100 to-ports=\
8000
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=lte1_digi \
routing-table=rtab-1 suppress-hw-offload=no
/ip service
set telnet address=192.168.0.0/16
set ftp address=192.168.0.0/16
set www address=192.168.0.0/16
set ssh address=192.168.0.0/16
set www-ssl address=192.168.0.0/16
set api address=192.168.0.0/16
set winbox address=192.168.0.0/16
set api-ssl address=192.168.0.0/16
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup-only-in-table disabled=no src-address=192.168.99.0/24 \
table=rtab-1
/system clock
set time-zone-name=Europe/Bucharest
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
