Hello.
Short story: I want to separate two wireless networks and bridge(?) one of them to a wired interface, while upholding high security.
I have a 2011UiAS and 4 cAP ac running capsman. I also have 4 UniFi AP-AC Pro and some wired receipt printers (gastrofix POS). Todays setup works fine, but the UniFi’s have died one after one. Now I’m down to only 1(!) working. All cAP ac are just fine.
The cAP ac is giving guest wifi (dhcp), while the UniFi’s handle POS equipment (5 iPads and 4 iZettle, dhcp). Receipt printers are wired (with static IP).
The cAP ac’s are connected to a managed Mikrotik POE switch (eth3) to eliminate the POE dongles, while UniFi’s and receipt printers are all on an unmanaged switch (eth4) the cAP ac’s could also be on a unmanaged switch (separate), i just used what I had). Broadband on eth1, switch for office computers on eth2.
Everything works fine today.
However, I need to quickly replace the dead UniFi’s. So I was hoping to move the POS network over to my cAP ac’s and separate guest and POS network into vlans. And bridge wired and wireless POS vlans.
It’s very important that guests can’t access anything else on the net than internet. And of course outsiders can’t get into the network.
I’ve exported my current config and modified it to add the POS network (which was previously done locally in the UniFi APs). On the bottom is the current config.
Could someone check the script and tell me if I did something wrong, could be better or if I should set it up entirely different?
Also, I’m not sure if capsman has any pros or cons in my case? I might expand to 5 cAP ac’s in the near future. And running a script locally on each AP if I change config some times isn’t that big of a deal.
New, modified config (not tested yet).
# mar/07/2024 20:07:04 by RouterOS 6.49.13
# software id = TRSV-ISX2
# model = 2011UiAS
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2412 name=Ch01_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2437 name=Ch06_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2462 name=Ch11_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2467 name=Ch12_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2472 name=Ch13_20M_24G tx-power=10
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5180 name=Ch36_20M_5G tx-power=20
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5200 name=Ch40_20M_5G tx-power=20
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5220 name=Ch44_20M_5G tx-power=20
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5240 name=Ch48_20M_5G tx-power=20
#previous config (only guest APs)
#/interface bridge
#add fast-forward=no name=AP_bridge
#add admin-mac=E4:8D:8C:2D:27:5A auto-mac=no comment=TrustedBridge name=WorkBridge
set [ find default-name=ether1 ] name=eth1_WAN
set [ find default-name=ether2 ] name=eth2_kontor
set [ find default-name=ether3 ] name=eth3_MikrotikAPs
set [ find default-name=ether4 ] name=eth4_gastrofix_wired
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
#/caps-man datapath
#add bridge=AP_bridge bridge-horizon=1 client-to-client-forwarding=no local-forwarding=no name="My Public"
/interface vlan
add vlan-id=10 interface=eth2_kontor name=EmployeeLAN_VLAN
add vlan-id=20 interface=eth3_MikrotikAPs name=GuestWIFI_VLAN
add vlan-id=30 interface=eth3_MikrotikAPs name=GastrofixWIFI_VLAN
add vlan-id=40 interface=eth4_gastrofix_wired name=GastrofixLAN_VLAN
add name=Gastrofix_bridge
add bridge=Gastrofix_bridge interface=GastrofixLAN_VLAN
add bridge=Gastrofix_bridge interface=GastrofixWIFI_VLAN
/caps-man rates
add basic=9Mbps name="GN Only - No B rates" supported=9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs=""
#5GHz
/caps-man configuration
add country=norway datapath.local-forwarding=yes datapath.vlan-id=30 datapath.vlan-mode=use-tag name="GastrofixConfig5G" distance=indoors installation=indoor mode=ap security.authentication-types=wpa-psk,wpa2-psk security.passphrase=Test1234 ssid="Gastrofix_5GHz"
add country=norway datapath.local-forwarding=no datapath.vlan-id=20 datapath.vlan-mode=use-tag name="GuestPublicConfig5GHz" distance=indoors installation=indoor mode=ap ssid="Public"
/caps-man interface
add channel=Ch36_20M_5G configuration="GastrofixConfig5G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=C4:AD:34:14:34:2B master-interface=none radio-mac=C4:AD:34:14:34:2B radio-name=C4AD3414342B name=5GHz-AP_Kontor
add channel=Ch40_20M_5G configuration="GastrofixConfig5G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AF:1A master-interface=none radio-mac=74:4D:28:F9:AF:1A radio-name=744D28F9AF1A name=5GHz-AP_Bar
#add channel=Ch44_20M_5G configuration="GastrofixConfig5G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=xx master-interface=none radio-mac=xx radio-name=xx name=5GHz-AP_Messanin
add channel=Ch48_20M_5G configuration="GastrofixConfig5G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AA:6D master-interface=none radio-mac=74:4D:28:F9:AA:6D radio-name=744D28F9AA6D name=5GHz-AP_Chambre
add channel=Ch36_20M_5G configuration="GuestPublicConfig5GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=C4:AD:34:14:34:2B master-interface=none radio-mac=C4:AD:34:14:34:2B radio-name=C4AD3414342B name=5GHz-AP_Kontor
add channel=Ch40_20M_5G configuration="GuestPublicConfig5GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AF:1A master-interface=none radio-mac=74:4D:28:F9:AF:1A radio-name=744D28F9AF1A name=5GHz-AP_Bar
#add channel=Ch44_20M_5G configuration="GuestPublicConfig5GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=xx master-interface=none radio-mac=xx radio-name=xx name=5GHz-AP_Messanin
add channel=Ch48_20M_5G configuration="GuestPublicConfig5GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AA:6D master-interface=none radio-mac=74:4D:28:F9:AA:6D radio-name=744D28F9AA6D name=5GHz-AP_Chambre
#2.4GHz
add country=norway datapath.local-forwarding=yes datapath.vlan-id=30 datapath.vlan-mode=use-tag name="GastrofixConfig24G" distance=indoors installation=indoor mode=ap security.authentication-types=wpa-psk,wpa2-psk security.passphrase=Test1234 ssid="Gastrofix_2.4GHz" rates="GN Only - No B rates"
add country=norway datapath.local-forwarding=no datapath.vlan-id=20 datapath.vlan-mode=use-tag name="GuestPublicConfig24GHz" distance=indoors installation=indoor mode=ap ssid="Public" rates="GN Only - No B rates"
/caps-man interface
add channel=Ch01_20M_24G configuration="GastrofixConfig24G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AF:19 master-interface=none radio-mac=74:4D:28:F9:AF:19 radio-name=744D28F9AF19 name=2.4GHz-AP_Bar
add channel=Ch06_20M_24G configuration="GastrofixConfig24G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=C4:AD:34:14:34:2A master-interface=none radio-mac=C4:AD:34:14:34:2A radio-name=C4AD3414342A name=2.4GHz-AP_Kontor
add channel=Ch11_20M_24G configuration="GastrofixConfig24G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AA:6C master-interface=none radio-mac=74:4D:28:F9:AA:6C radio-name=744D28F9AA6C name=2.4GHz-AP_Chambre
#channel 12 or 13: add channel=Ch12_20M_24G configuration="GastrofixConfig24G" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=xx master-interface=none name=2.4GHz-AP_Messanin radio-mac=xx radio-name=xx
add channel=Ch01_20M_24G configuration="GuestPublicConfig24GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AF:19 master-interface=none radio-mac=74:4D:28:F9:AF:19 radio-name=744D28F9AF19 name=2.4GHz-AP_Bar
add channel=Ch06_20M_24G configuration="GuestPublicConfig24GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=C4:AD:34:14:34:2A master-interface=none radio-mac=C4:AD:34:14:34:2A radio-name=C4AD3414342A name=2.4GHz-AP_Kontor
add channel=Ch11_20M_24G configuration="GuestPublicConfig24GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=74:4D:28:F9:AA:6C master-interface=none radio-mac=74:4D:28:F9:AA:6C radio-name=744D28F9AA6C name=2.4GHz-AP_Chambre
#channel 12 or 13: add channel=Ch12_20M_24G configuration="GuestPublicConfig24GHz" configuration.frame-lifetime=10ms disabled=no l2mtu=1600 mac-address=xx master-interface=none name=2.4GHz-AP_Messanin radio-mac=xx radio-name=xx
add name=WAN
add name=LAN
add name=WinboxAccess
add name=gastrofix_dhcp_pool ranges=192.168.7.120-192.168.7.254
add name=guest_dhcp_pool ranges=192.168.88.20-192.168.88.250
add address-pool=gastrofix_dhcp_pool disabled=no interface=GastrofixWIFI_VLAN lease-time=23h59m59s name=gastrofix_dhcp_server
add address-pool=guest_dhcp_pool disabled=no interface=GuestWIFI_VLAN lease-time=2h59m name=guest_dhcp_server
/system logging action
set 0 memory-lines=3000
set 1 disk-file-count=10 disk-lines-per-file=3000
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man access-list
add action=accept allow-signal-out-of-range=10s comment="-85..120 accept" disabled=no signal-range=-85..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s comment="-120..-86 reject" disabled=no signal-range=-120..-86 ssid-regexp=""
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=eth3_MikrotikAPs
/caps-man provisioning
add action=create-dynamic-enabled comment="2.4GHz 802.11g capable radios" hw-supported-modes=gn master-configuration="GastrofixConfig24G" name-format=prefix-identity name-prefix=2.4GHz-
add action=create-dynamic-enabled comment="5GHz 802.11ac capable radios" hw-supported-modes=ac master-configuration="GastrofixConfig5G" name-format=prefix-identity name-prefix=5GHz-
add action=create-dynamic-enabled comment="2.4GHz 802.11g capable radios" hw-supported-modes=gn master-configuration="GuestPublicConfig24GHz" name-format=prefix-identity name-prefix=2.4GHz-
add action=create-dynamic-enabled comment="5GHz 802.11ac capable radios" hw-supported-modes=ac master-configuration="GuestPublicConfig5GHz" name-format=prefix-identity name-prefix=5GHz-
#/interface bridge port
#add bridge=AP_bridge interface=eth3_MikrotikAPs
#set discover-interface-list=all lldp-med-net-policy-vlan=1
set discover-interface-list=WinboxAccess
add interface=eth1_WAN list=WAN
add interface=eth2_kontor list=LAN
add interface=eth3_MikrotikAPs list=LAN ##needed?
add interface=eth4_gastrofix_wired list=LAN
#add interface=AP_bridge list=LAN
add interface=eth2_kontor list=WinboxAccess
#add interface=GastrofixWIFI_VLAN list=WinboxAccess
add address=x.x.x.x/24 network=x.x.x.0 interface=eth1_WAN #public IP hidden in forum
add address=192.168.1.1/24 network=192.168.1.0 interface=eth2_kontor
add address=192.168.7.1/24 network=192.168.7.0 interface=eth4_gastrofix_wired
add address=192.168.88.1/24 network=192.168.88.0 interface=GuestWIFI_VLAN
#add address=192.168.8.1/24 network=192.168.8.0 interface=ether5
/ip arp
add address=192.168.7.41 interface=GastrofixWIFI_VLAN mac-address=FE:67:3A:11:0F:D0
#add address=192.168.7.41 interface=eth4_gastrofix_wired mac-address=FE:67:3A:11:0F:D0
/ip cloud
set update-time=no
/ip dhcp-server lease
add address=192.168.7.247 client-id=1:78:8a:20:4b:4:a6 mac-address=78:8A:20:4B:04:A6 server=gastrofix_dhcp_server
add address=192.168.7.0/24 comment="DHCP for Gastrofix" dns-server=193.75.75.75,192.168.7.1 gateway=192.168.7.1 netmask=24
#add address=192.168.8.0/24 comment="DHCP for Gastrofix AP" dns-server=193.75.75.75,192.168.8.1 gateway=192.168.8.1
add address=192.168.88.0/24 comment="DHCP for Guests" dns-server=193.75.75.75,193.75.75.193 gateway=192.168.88.1
set allow-remote-requests=yes servers=193.75.75.75,193.75.75.193
/ip firewall address-list
add list=AdminAccess address=192.168.1.0/24
add list=bogons address=0.0.0.0/8
add list=bogons address=172.16.0.0/12
add list=bogons address=10.0.0.0/8
add list=bogons address=169.254.0.0/16
add list=bogons address=127.0.0.0/8
add list=bogons address=224.0.0.0/4
add list=bogons address=198.18.0.0/15
add list=bogons address=192.0.0.0/24
add list=bogons address=192.0.2.0/24
add list=bogons address=198.51.100.0/24
add list=bogons address=203.0.113.0/24
add list=bogons address=100.64.0.0/10
add list=bogons address=240.0.0.0/4
add list=bogons address=192.88.99.0/24
add action=accept chain=input comment="accept established,related" connection-state=established,related
add action=drop chain=input comment="drop invalid" connection-state=invalid
#add action=drop chain=forward dst-address=77.66.21.133 in-interface=AP_bridge
add action=drop chain=forward dst-address=77.66.21.133 in-interface=GuestWIFI_VLAN
add action=accept chain=input comment="Admin Access to Router" src-address-list=AdminAccess
add action=accept chain=input comment="allow LAN to DNS-TCP" dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="allow LAN to DNS-UDP" dst-port=53 in-interface-list=LAN protocol=udp
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="CAPsMAN accept all local traffic" dst-port=5246,5247 protocol=udp src-address=127.0.0.1
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 log=yes log-prefix="acceot local loopback CAPsMAN"
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address-type=local src-address-type=local
add action=drop chain=input comment="Drop All Else" log-prefix=DROP-FIREWALL
add action=fasttrack-connection chain=forward comment=fasttrack connection-state=established,related
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="Allow all LAN (Office, Guest and POS) Traffic to Internet" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=drop chain=forward comment="DROP ALL Else"
add action=accept chain=forward comment="Allow Port Fowarding if required" connection-nat-state=dstnat
add action=drop chain=forward comment="DROP All Else"
add action=src-nat chain=srcnat comment="Source_NAT for All Users" ipsec-policy=out,none out-interface=eth1_WAN to-addresses=x.x.x.x #public IP hidden in forum
add action=redirect chain=dstnat comment="Force Users to Router DNS -TCP" dst-port=53 protocol=tcp
add action=redirect chain=dstnat comment="Force Users to Router DNS -UDP" dst-port=53 protocol=udp
add action=accept chain=srcnat disabled=yes ipsec-policy=out,none out-interface=eth1_WAN
/ip firewall raw
add action=drop chain=prerouting comment="Drop all non-internet networks" src-address-list=bogons
add distance=1 gateway=x.x.x.x #public IP hidden in forum
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes port=2200
set www-ssl disabled=no
set api disabled=yes
set winbox address=192.168.1.20/32,192.168.1.21/32
#set winbox address=192.168.1.20/32,192.168.1.21/32,192.168.88.5/32
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/lcd
set default-screen=stat-slideshow
/system clock
set time-zone-name=Europe/Oslo
/system identity
set name=Router-Kontor
/system logging
add action=disk topics=info,critical,error,info
/system ntp client
set enabled=yes primary-ntp=79.160.13.250 secondary-ntp=162.159.200.1
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=WinboxAccess
/tool mac-server ping
set enabled=no
/tool romon
set enabled=yes
Current config which runs today (without wireless POS, vlan, etc):
# model = 2011UiAS
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled \
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled \
add admin-mac=E4:8D:8C:2D:27:5A auto-mac=no comment=TrustedBridge name=\
WorkBridge
/caps-man datapath
add bridge=AP_bridge bridge-horizon=1 client-to-client-forwarding=no \
add country=norway datapath="My Public" distance=indoors frame-lifetime=\
10ms installation=indoor mode=ap name="My Public 5GHz" ssid=\
"My Restaurant"
10ms installation=indoor mode=ap name="My Public 2.4GHz" ssid=\
"My Restaurant"
/caps-man rates
add basic=9Mbps name="GN Only - No B rates" supported=\
add name=WAN
add name=LAN
add name=gastrofix_dhcp ranges=192.168.7.120-192.168.7.254
add name=guest_dhcp ranges=192.168.88.10-192.168.88.250
add name=gastrofix_wifi_dhcp ranges=192.168.8.120-192.168.8.254
add address-pool=gastrofix_dhcp disabled=no interface=eth4_gastrofix \
add address-pool=guest_dhcp disabled=no interface=AP_bridge lease-time=2h30m \
name=guest_dhcp
add address-pool=gastrofix_wifi_dhcp disabled=no interface=ether5 lease-time=\
23h59m59s name=gastrofix_wifi_dhcp
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
add action=accept allow-signal-out-of-range=10s comment="-85..120 accept" \
add action=reject allow-signal-out-of-range=10s comment="-120..-86 reject" \
/caps-man manager
add disabled=no interface=AP_bridge
add action=create-dynamic-enabled comment="2.4GHz 802.11g capable radios" \
hw-supported-modes=gn master-configuration="My Public 2.4GHz" \
add action=create-dynamic-enabled comment="5GHz 802.11ac capable radios" \
hw-supported-modes=ac master-configuration="My Public 5GHz" \
add interface=eth4_gastrofix list=LAN
add interface=eth4_gastrofix list=WinboxAccess
add interface=ether5 list=WinboxAccess
add address=xxxx/24 interface=eth1_WAN network=xx.xxx
add address=192.168.1.1/24 interface=eth2_kontor network=192.168.1.0
add address=192.168.7.1/24 interface=eth4_gastrofix network=192.168.7.0
add address=192.168.88.1/24 interface=AP_bridge network=192.168.88.0
add address=192.168.8.1/24 interface=ether5 network=192.168.8.0
/ip arp
add address=192.168.7.41 interface=eth4_gastrofix mac-address=\
FE:67:3A:11:0F:D0
/ip cloud
set update-time=no
add address=192.168.7.247 client-id=1:78:8a:20:4b:4:a6 mac-address=\
add address=192.168.7.0/24 comment="DHCP for Gastrofix" dns-server=\
add address=192.168.8.0/24 comment="DHCP for Gastrofix AP" dns-server=\
add address=192.168.88.0/24 comment="DHCP for Guests" dns-server=\
add address=192.168.1.0/24 list=AdminAccess
add address=0.0.0.0/8 list=bogons
add address=172.16.0.0/12 list=bogons
add address=10.0.0.0/8 list=bogons
add address=169.254.0.0/16 list=bogons
add address=127.0.0.0/8 list=bogons
add address=224.0.0.0/4 list=bogons
add address=198.18.0.0/15 list=bogons
add address=192.0.0.0/24 list=bogons
add address=192.0.2.0/24 list=bogons
add address=198.51.100.0/24 list=bogons
add address=203.0.113.0/24 list=bogons
add address=100.64.0.0/10 list=bogons
add address=240.0.0.0/4 list=bogons
add address=192.88.99.0/24 list=bogons
add action=accept chain=input comment="accept established,related" \
add action=accept chain=input comment="Admin Access to Router" \
add action=accept chain=input comment="allow LAN to DNS-TCP" dst-port=53 \
add action=accept chain=input comment="allow LAN to DNS-UDP" dst-port=53 \
add action=accept chain=input comment="CAPsMAN accept all local traffic" \
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 \
"defconf: accept to local loopback (for CAPsMAN)" dst-address-type=local \
add action=fasttrack-connection chain=forward comment=fasttrack \
add action=accept chain=forward comment="accept established,related" \
add action=accept chain=forward comment="accept in ipsec policy" \
add action=accept chain=forward comment="accept out ipsec policy" \
add action=accept chain=forward comment="Allow Port Fowarding if required" \
add action=src-nat chain=srcnat comment="Source_NAT for All Users" \
ipsec-policy=out,none out-interface=eth1_WAN to-addresses=xxxxxx
add action=redirect chain=dstnat comment="Force Users to Router DNS -TCP" \
add action=redirect chain=dstnat comment="Force Users to Router DNS -UDP" \
add action=accept chain=srcnat disabled=yes ipsec-policy=out,none \
/ip firewall raw
add action=drop chain=prerouting comment="Drop all non-internet networks" \
add distance=1 gateway=xxxxx
/ip service
/ip ssh
/lcd
/system clock
/system identity
/system logging
/system ntp client
set enabled=no
/tool mac-server
set enabled=no
/tool romon
set enabled=yes
