separated speed
HEllo ALL
i am using mikrotik on pc using hotspot and give each user certain speed 200 K download and 100 K upload and i have HSF server to share files in another computer with low speed i want to separate HSF server file sharing speed from hotspot speed 200K/sec how can i find that way can i use special port or what plz help
I assume the HSF server is attached directly to the mikrotik hotspot server. You will have to mark the packets that are destined for the HSF server using mangle rules and then apply queues based on those packet marks.
http://www.mikrotik.com/testdocs/ros/3.0/qos/mangle.php
http://www.mikrotik.com/testdocs/ros/3.0/qos/queue.php
THnx for yr help but i found general topics can u put what i must write un terminal after putting files in hotspot folder
i want to write (CLICK HERE) link in my hotspot page linked to hotspot HSF file
thnx
Please explain precisely what you are trying to achieve?
what do you mean by “HSF”?
Dear Sir
HSF mean http file server program used to share file over my network using separated pc with windows xp
you can find details here http://www.rejetto.com/hfs/
plz help me to share my file to all user using pc or using mikrotik server but i want to share file with high speed lan as i use subnet mask=8 to bisable netcut plz help my by any way thnx…
