I have a requirement for an unusual system configuration and I think the RB2011iL will work. I’m new to these routers, so please bear with me.
I have network (10.0.0.x) in building A, for an IP phone system, that is fed from a cable modem through a Netgear router.
A second network (192.168.1.x) exists in building B, for various computers, and is fed from a T1 through a router.
The two physical networks are connected together over a wireless PTP link (Radwin). So, both networks are on the same physical ethernet cabling. Devices on the 10.0.0.x network access the internet through the Netgear router in building A and devices on the 192.168.1.x network access the internet through the router in building B.
This is all fine and works well. The Radwin wireless link is set up on 10.0.0.x network for management access, however, it passes everything through as if it’s just a long ethernet cable (or fiber cable). There are no VLANS on this network.
What I need to do is use the internet connection in building B for a backup to the internet connection in building A.
Using an RB2011iL, set up with dual-WAN failover and located in building A, is the easy part (I think). The WAN-2 port would be set up to ‘see’ the router in building B as a gateway to the second internet connection. I would be double-natting here, but it would give me my backup connection.
The problem is, figuring out how to connect the WAN-2 port to the network and not create a ‘loop’, since the wireless connection carries both networks (10.0.0.x and 192.168.1.x).
So, I’m thinking that I need a way to ‘split’ the two networks at the wireless link, on the building A side.
Port 1 - WAN-1 (Internet Feed from Cable Modem)
Port 2 - WAN-2 (Internet Feed T1 (carried over Wireless Link from building B)
Port 3, 4 - LAN (10.0.0.x)
Port 8 - 10.0.0.x Network
Port 9 - 192.168.1.x Network
Port 10 - Connection to Wireless Link (carries both networks)
This would keep the two networks isolated in building A, so that the WAN-2 port could be connected to Port 6 and be isolated from the 10.0.0.x network in building A.
In effect, the router would need to route traffic for anything on the 10.0.0.x network, to Port 8 and traffic for anything on the 192.168.1.x network, to Port 9.
10.0.0.x >-----------|
|--------> Wireless Link (carries both 10.0.0.x and 192.168.1.x network traffic)
192.168.1.x >-----------|
Is it possible to do this with an RB2011iL?
John Rayfield, Jr.
