Seperate Ethernet Ports...: RouterBoard 2011UAS-RM
I just try to set up the following scenario and I am stuck at the very first step.
Ethernet 6,7,8 should be configured as “IP less” Ethernet Ports.
On Every Port one single pppoe client should be bound.
On Ethernet Port 2 a switch is connected where all internal clients should login with their own internal pppoe account
On Ethernet Port 5 the management Network should be connected…
My first step ought be to sepearate the default Ethernet config, default every ethernet-port is bridged with any other it seems.
But: How to do that? I would really like to start with Port 5 assigning an IP so I don’t get locked out from the beginning, but
Port 5 is not available for assigning a static ip…?
Any hints? (May be for the following steps as well…? :wink:
BTW: Every time I look in the webinterface of a new device the first time, I think “thats been forgotten, that is missing as well…” but the mikrotik router is sheerly overloaded with extras, options and settings…:slight_smile:
I am astounded!
Thanks a lot for yout help!
Cheers,
Uli
If you want individual ports , you have to delete these ports of they are member of a bridge abd also make sure master-port is set to none.
How do I make sure that, lets say, ethernet port 2 is assigned to a fixed adress if I want to delete all ports from the bridge?
Or is it totally different as the linux bridgeutils do that?
There, you have eth0 to 4 briged to br0
if you set an IP only for br0 and you release all interfaces from br0 you locked yourself out…
Cheers,
UG
