mino
1
two brand new CCR, I’m connecting a null-modem serial cable (tested OK), but it seems impossible to connect to the serial console.
I’ve tested 9600, 19200 and 115200 all 8N1 with flow control off.
I have no problem in using the serial console of other non-CCR mikrotik products.
What am I doing wrong?
cbrown
2
The default baud rate is 115200 unless you have changed it in /system routerboard settings.
Are you sure you cable is okay? Do you have another to try?
mino
3
just to confirm: I’m supposed to use a standard null-modem cable, right?
can you confirm the pinout?
thanks!
cbrown
4
