Serial Console for RB2011
Any idea what’s the correct settings using putty to connect to RB2011 serial port?
I notice the default baud rate configuration in the router is “auto”. I changed it to 57600 and managed to connect to it only AFTER it boot up. When booting, it still showing garbage code.
  • Auto should work fine.
    I have mine set to 115200.
    Make sure you have the correct cable (blue Cisco console cable is ok).
    Make sure you have the correct comm port selected on your pc.
thanks w0lt, so it’s not auto after all, it’s 115200 :slight_smile:
