I am looking to connect to the serial console port of my CRS328-24P-4S+ switch. I am looking to take an RJ45 Cat 5 cable wired to T-568B standard on one end and pins 3 and 6 connected to this USB to TTL board: https://www.amazon.com/dp/B0DLGQ9RXW
Has anyone done this successfully? When I connect using a baud rate of 115,200 to match my switch, I get garbage characters printed to the console or a string of C characters.
root@nexus:~# tio /dev/ttyCH343USB7
[11:30:05.448] tio v3.9
[11:30:05.448] Press ctrl-t q to quit
[11:30:05.448] Connected to /dev/ttyCH343USB7
C6
CCCCCC
That USB thingy seems TTL.
The serial is RS-232.
Within limits, TTL can be considered a subset of RS-232 BUT it has inverted logic, so even if the 0-5V of the TTL is correctly sensed by the RS-232 0’s will be 1’s and viceversa. Additionally (it depends on the RS-232 on the Mikrotik side voltage and on the tolerance of the TTL converter) there is a risk of frying the TTL adapter: https://www.nicerf.com/news/rs232-rs485-and-ttl.html
In any case it is not a very good idea to use only two wires a ground is usually needed.
