Hi, we are WISP considering moving our network to Mikrotik routers.
I’m trying to make script for General Electric UPS’s we have, but get strange beehive of serial-terminal.
When trying to communicate to the UPS, I only get “p” and beeps. This is the terminal output (values for connection are correct).
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.41 (c) 1999-2017 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@CoreRouter] > /port print detail
Flags: I - inactive
0 name="serial0" used-by="" device="" channels=1 baud-rate=1200 data-bits=8 parity=none stop-bits=1 flow-control=none
1 name="serial1" used-by="" device="" channels=1 baud-rate=auto data-bits=8 parity=none stop-bits=1 flow-control=none
[admin@CoreRouter] > /system serial-terminal serial0
[Ctrl-A is the prefix key]
p
p
p
p
p
When trying PuTTY for remote serial access get even more wired staff:
login as: serial
serial@192.168.3.178's password:
▒p▒
▒▒p▒
▒▒p▒
▒▒p▒
Tried null-modem cable and a LOOP one also.
Already run out off of ideas.
Any clue?
