is it possable to rout through two router boards via serial
pc(rs232)serial(rb433uah)-----wireless-----(433uah)serial(rs232)device
Serial ports cannot be used for packet forwarding unless you have modems connected to serial ports.
@MT What about ppp using a null modem cable? It works.
@xezen: Is the goal to have a remotely controlled serial port or a remote serial connected network device?
If the former, then there is an easier way to make the remote serial port available:
http://wiki.mikrotik.com/wiki/Serial_Port_Usage
This is one of the best “free” features of ROS.
ok will try it out
main aim to get serial device to talk to anoter device
