Serial V.35 WAN router
Does RouterOS support any V.35 serial (HDLC) PCI boards so it can be used as WAN router? Is there any appliance boxes running RouterOS with an v.35 interface?
Any tips of a cheap but reliable Serial-Ethernet bridge or router to put outside of the Mikrotik to run the link otherwise?
This will be used in Syria and Iran where the embargo restrictions stops us from using cisco routers.
Oh, sometimes you think this forum has answers for everything so you forget to accually check the documentation before posting questions! shame
I found in the docs there a number of supported V35 boards. Nice!
So, lets rephrase the question. Is there any Mikrotik or other appliances equipped with a V35 port? I really don’t want to mess with a normal PC and installing a PCI board, installing RouterOS and so on.
My customers would want to order an off-the-shelf box to just load the RouterOS config into. Any such box avaiable?
The question about a V35-Ethernet bridge or router is still valid though if no such box is available.
get a j2320 from juniper in the modular version, it has everything included. of course, not the cheapest one but if you think about ciscos, juniper is worth a try. the 2320 can be bought with 2- or 4-port serial cards.
