serial0 dialin possible???
hello,
i have successfully configured a dialin server using Mikrotik router os, i have two serial ports for the pc that i am using. i would like to use the 2 ports for dialin but i can’t seem to find a way to use serial0 for dialin. i can’t remove it to be used for dialin.
is there a way to use serial0 for dialin, im from the philippines and most of the pci cards mentioned in this forum are not available here. please help
Usually it is used by the system console. you can disable it if you do not need it.
