serious problem with CCR1036-12G-4S
in CCR1036-12G-4S i installed Userman and Add about 800 users in it.
the users connect to the internet via pptp vpn and userman radius.
when nearly 200 users are connected mikrotik pass wont work and any remain users wont be able to connect or sometimes after a day when traffic is off and any user is not connected it will happen and i can enter it without password and reboot it after this everything goes fine!
appreciate for your help,
At our company, this is something that we handle all the time. We have handled VPN connections in the hundreds of thousands. One of the limitations with the routers is that even though they have a lot of horse power, they don’t handle large numbers of VPN connections the way you would expect. In truth, the routers handle 200 or 500 or 1000 connections the same way it would handle just a handful of connections. You might consider looking at ways to control your connections. There are lots of way to go about this and not all of those solutions would relay completely on the CCRs.
