Dear Helpers,
I am having a problem to connect my pxe boot system pxe boot system is serva which is checked as proxy dhcp and binl recieve from mikrotik ccr1009 router
problem is system in same vlan can get to install windows on network but others vlan can not
Mikrotik router can connect via eth 3 port to cisco sf300 switch ( i use only one port to cisco vlans combined on one port eth3) which has trunk and access setting already setup all vlans get thier Ips accordingly no issue on vlans and access problems
vlan1: 192.168.1.0/24 (192.168.1.100 pxe server PC installed)
vlan2: 192.169.4.0/24
vlan3: 192.169.5.0/24
vlan1 and vlan2 can ping each other
using options 67 and 66 and bootp to static on vlan but nothing happened
Regards
Ahsan
