Hello an greetings from Northern-Germany,
i am new in touch with mikrotik Router OS an willing to spend more time on it. so i wish to use chs in hyper v with 4 vPorts and bridge funktion.
Is it a BUG or my FAULT ? there is no way to subbmit packets throu, even with or without legacy adapters.
can somebody help me out ?
kind regards
Norman
If something so simple as bridge does not work, it is either mis-configuration or bug.
- Could you firstly describe closer, what are you trying to achieve and what exactly does not work? (i.e. how to reproduce the error).
- Does normal forwarding or at least Rx/Tx on Ethernet ports works?
- Is it related to any bridged traffic or is there any other requirement? (VLANs etc)
- Does it happen with other versions? (older HyperV and/or older CHR)
edit: @cdiedrich excelent point! do you still accept bets on it?
I could bet that it’s related to Hyper-V not being configured for promiscous mode.
-Chris
