server access to specified ip
hello masters,
I am facing a strange problem some time i saw a very heavy traffic on my server upto 90mbps . In mikrotik when i uses torch to check from where this traffic is comming their is some public ip which is creating this proble I want to have access to server to some specified ip ( xx.xx.xx.x/25) and for the other ip the traffic will be dropped
Hope for the positive reply
Thanks in advance
Sounds like you need to implement some bandwidth management. Without knowing your exact traffic patterns and needs, I wouldn’t know how to advise you on this, but the WIKI has some pretty decent examples that should get you started. Also search for a PCQ/QOS script.. there’s a few floating around out there.
Good luck!
