Bom dia a todos, desculpem mas meu ingles é péssimos, então postarei em Portugues e Ingles traduzido.
Venho pedir ajuda aos amigos, pois depois de uns 3 anos que migrei para PPPOE, do nada o Server começou a travar, no log aparece erros de "Time Out " no Radius, entrei em contato com a empresa do sistema Radius, eles me informaram que tinha problema, mas nao tinha na haver com a conexão cliente server. Bom, troquei de maquina, memoria, HD, CPU, Placa Mae, teste de memoria, de HD, de stress, resumindo, verifiquei tudo.
Licenciei o MK para a versão 4.13… atualizei para a 4.15… continuou a travar, menas vezes mas continuou. Um amigo aconselhou a fazer um downgrade para a 4.11, ficou uns 20 dias sem travar agora voltou a travar.
Vou enviar algumas informações aos amigos, assim q puder enviarei prints das telas que aparencem nos logs, e na propria tela do Winbox.
Grato desde ja pela atenção de todos.
Good morning everyone, sorry but my English is bad, then I’ll post in Portuguese and English translation.
I’ve been asking for help to friends, because after about three years that I migrated to PPPOE, of anything started freezing Server, appears in the log errors “Time Out” at Radius, I contacted the company Radius system, they informed me that was okay, but not be had in connection with the client server. Well, I changed the machine, memory, HDD, CPU, Motherboard, test memory, HD, stress, in short, checked everything.
MK graduated to version 4.13 … upgraded to 4.15 … continued to hang, but continued menas times. A friend advised him to make a downgrade to 4.11, was about 20 days now without crashing halt again.
Will send some information to friends, so q can send screenshots of the design that appearance in the logs, and Winbox own screen.
Thank you in advance for your attention.
jan/03/2011 08:47:31 system,error,critical router was rebooted without proper shutdown
jan/04/2011 11:21:13 system,error,critical login failure for user admin from 201.64.198.243 via winbox
jan/07/2011 10:34:22 system,error,critical router was rebooted without proper shutdown
jan/10/2011 11:01:56 system,error,critical login failure for user admin from 201.64.198.164 via winbox
jan/10/2011 11:02:29 system,error,critical login failure for user admin from 201.64.198.164 via winbox
jan/10/2011 11:02:44 system,error,critical login failure for user admin from 201.64.198.164 via winbox
jan/14/2011 10:19:57 system,error,critical login failure for user admin via winbox
jan/20/2011 15:55:32 system,error,critical System rebooted because of kernel failure
[paulo@SRV_PPPOE] >
[paulo@SRV_PPPOE] > system hardware print
multi-cpu: no
[paulo@SRV_PPPOE] > system resource print
uptime: 55m5s
version: “4.11”
free-memory: 231744kB
total-memory: 255716kB
cpu: “AMD”
cpu-count: 1
cpu-frequency: 1800MHz
cpu-load: 42
free-hdd-space: 38311192kB
total-hdd-space: 38488468kB
write-sect-since-reboot: 32674
write-sect-total: 214074
architecture-name: “x86”
board-name: “x86”
platform: “MikroTik”
[paulo@SRV_PPPOE] > interface pppoe-server server print
Flags: X - disabled
0 service-name=“PPPOE” interface=CLIENTES max-mtu=1480 max-mru=1492 mrru=disabled authentication=pap
keepalive-timeout=10 one-session-per-host=no max-sessions=0 default-profile=default
[paulo@SRV_PPPOE] > radius print
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 X ;;; RADIUS IP INTERNO
ppp 172.17.254.2 xxxxxxxx
1 ;;; RADIUS IP VALIDO
ppp 200.183.146.195 xxxxxxx
