Server with multiple ip addresses and services
I’ve got server with several ip addresses. On each address there are some services (web, NTP, SNMP, …). Is it possible to poll this server and all its services as one device?
Thanks.
Petr
I have the same problem
Not as one device. The Dude only polls/probes the primary IP address. You’d have to make multiple devices if you want to poll the services on the other IP addresses.
I’m not sure in this, but have you tried to install/activate a snmp service on the server?
If the Dude can access the server with snmp, it eventually detects all Interfaces.
