No problem. Steve is the English equivalent of my first name. Many steve are registered so steve800 ... Unfortunately, the browser does not refresh automatically when a new post is received ...
In the meantime, I made a config export as you requested, I hope it will be right ... I tried to hide sensitive data like username, public IP address, etc. I hope it doesn't cause a problem.
feb/06/2022 19:48:06 by RouterOS 6.49.2
software id = KR2J-EIA8
model = RBD52G-5HacD2HnD
serial number =
add admin-mac=B8:69:F4:C0:51:62 arp=proxy-arp auto-mac=no comment=defconf
name=bridge
add fast-forward=no name=bridge-VLAN10
add name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=
user-agn
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country=hungary disabled=no distance=indoors frequency=auto installation=
indoor mode=ap-bridge ssid=MikroTik-C05166 station-roaming=enabled
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-Ceee country=hungary disabled=no distance=indoors frequency=
auto installation=indoor mode=ap-bridge ssid=MikroTik-C05167
station-roaming=enabled wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=
dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" management-protection=
allowed mode=dynamic-keys name=guest-profile1 supplicant-identity=""
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=BA:69:F4:C0:51:66
master-interface=wlan1 multicast-buffering=disabled name=wlan3-guest
security-profile=guest-profile1 ssid=Guest station-roaming=enabled
vlan-id=10 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface vlan
add interface=wlan3-guest name=vlan10 vlan-id=10
/ip ipsec peer
add address=Public_IP_Office/32 name=peer1
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=user pfs-group=
none
add name=dhcp ranges=192.168.1.201-192.168.1.240
add name=dhcp_pool1 ranges=192.168.89.201-192.168.89.240
add name=dhcp_pool2 ranges=172.16.1.100-172.16.1.120
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=bridge-VLAN10 name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=bridge1 name=server1
/ppp profile
add bridge=bridge dns-server=192.168.1.254 local-address=dhcp name=
l2tp-bridge remote-address=dhcp
/queue simple
add name=Total target=""
add name=VOIP packet-marks=VoIP-Pkt parent=Total priority=2/2 target=""
add name=RTP packet-marks=RTP parent=Total priority=1/1 target=""
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge-VLAN10 interface=wlan3-guest
add bridge=bridge-VLAN10 interface=vlan10
add bridge=bridge1 interface=ether5 multicast-router=disabled
/interface l2tp-server server
set authentication=chap,mschap1,mschap2 default-profile=l2tp-bridge enabled=
yes use-ipsec=yes
add address=192.168.1.254/24 comment=defconf interface=ether2 network=
192.168.1.0
add address=192.168.89.1/24 interface=bridge-VLAN10 network=192.168.89.0
add address=172.16.1.1/24 interface=ether5 network=172.16.1.0
/ip cloud
set update-time=no
/ip dhcp-client
add address=172.16.1.0/24 dns-server=172.16.1.1,8.8.4.4,8.8.8.8 gateway=
172.16.1.1 netmask=24 ntp-server=84.2.46.19,148.6.0.1
add address=192.168.1.0/24 comment=defconf dns-server=
192.168.1.254,8.8.8.8,8.8.4.4,192.168.1.110 gateway=192.168.1.254
add address=192.168.89.0/24 dns-server=192.168.89.1,8.8.4.4 gateway=
192.168.89.1
set allow-remote-requests=yes servers=
8.8.8.8,8.8.4.4,193.110.57.4,193.110.56.8,208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.1.254 comment=defconf disabled=yes name=router.lan
add address=192.168.1.160 name=srv03
add address=192.168.1.2 name=sipi-linux
add address=192.168.1.1 name=srv02
add address=192.168.1.254 name=mikrotik
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee
d this subnet before enable it" disabled=yes list=bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you
need this subnet before enable it" list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=
bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=
"MC, Class D, IANA # Check if you need this subnet before enable it"
list=bogons
add action=accept chain=forward comment="forward l2tp/ipsec remote client"
dst-address=192.168.1.0/24 in-interface=all-ppp src-address=
192.168.1.0/24
dst-address=192.168.1.0/24 out-interface=all-ppp src-address=
192.168.1.0/24
add action=accept chain=input comment="defconf: accept established,related"
add action=drop chain=input comment=
"drop all DNS udp query not coming from LAN" dst-port=53 in-interface=
ether1 protocol=udp
"drop all DNS udp query not coming from LAN" disabled=yes dst-port=53
protocol=udp src-address=!192.168.0.0/23
"drop all DNS tcp query not coming from LAN" dst-port=53 in-interface=
ether1 protocol=tcp
"drop all DNS tcp query not coming from LAN" disabled=yes dst-port=53
protocol=tcp src-address=!192.168.0.0/23
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="allow l2tp/ipsec IKE (500)" dst-port=
500 in-interface-list=WAN protocol=udp
add action=accept chain=input comment="allow l2tp (1701)" dst-port=1701
add action=accept chain=input comment="allow l2tp/ipsec NAT (4500)" dst-port=
4500 in-interface-list=WAN protocol=udp
add action=accept chain=input comment="allow l2tp/ipsec vpn (ipsec-esp)"
in-interface-list=WAN protocol=ipsec-esp
add action=accept chain=input dst-address=Public_IP_Home in-interface-list=WAN
src-address=Public_IP_Office
"accept all from LAN works with drop input" in-interface=bridge
"accept all from LAN works with drop input" in-interface=bridge1
add action=accept chain=input disabled=yes dst-port=4569 protocol=udp
add action=accept chain=input disabled=yes dst-port=10000-20000 protocol=udp
add action=accept chain=input comment="accept ssh subnets" dst-address=
192.168.1.0/24 dst-port=22 protocol=tcp src-address=192.168.0.0/24
add action=drop chain=input comment="drop all input from blacklist"
src-address-list=ssh-blacklist
add action=add-src-to-address-list address-list=ssh-blacklist
address-list-timeout=2h chain=input comment=
"add IP address ssh request from WAN to blacklist" connection-state=new
dst-port=22 in-interface-list=WAN protocol=tcp
add action=drop chain=input comment="dropping port scanners"
src-address-list="port scanners"
add action=add-src-to-address-list address-list="port scanners"
address-list-timeout=5d chain=input comment="add port scanners to list"
connection-state=new protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="defconf: drop all not coming from LAN"
disabled=yes in-interface-list=!LAN
add action=drop chain=input comment="drop all other input" disabled=yes
add action=accept chain=input comment="accept traffic to Nethserver"
dst-address=Public_IP_Home dst-port=443 protocol=tcp
dst-address=Public_IP_Home dst-port=80 protocol=tcp
add action=accept chain=forward comment="port forward to Nethserver"
dst-address=192.168.1.150 dst-port=443 protocol=tcp
dst-address=192.168.1.150 dst-port=80 protocol=tcp
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward comment="defconf: accept established,related"
add action=accept chain=forward in-interface=bridge src-address=
192.168.1.0/24
add action=accept chain=forward in-interface=bridge1 src-address=
172.16.1.0/24
add action=accept chain=forward comment="forward openVPN to Zentyal"
dst-address=192.168.1.1 dst-port=1194 in-interface=pppoe-out1 protocol=
udp
add action=drop chain=forward comment="WiFi-Guest rule" in-interface=
bridge-VLAN10 out-interface=bridge
add action=drop chain=forward comment="WiFi-Guest rule" in-interface=bridge
out-interface=bridge-VLAN10
add action=drop chain=forward comment="Isolate port 2 from port 5" disabled=
yes dst-address=172.16.1.0/24 src-address=192.168.1.0/24
add action=drop chain=forward comment="Isolate port 5 from port2" disabled=
yes dst-address=192.168.1.0/24 src-address=172.16.1.0/24
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=
bogons
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=drop chain=forward comment="drop all other forward"
/ip firewall mangle
add action=change-mss chain=forward dst-address=192.168.0.0/24 new-mss=1350
passthrough=yes protocol=tcp src-address=192.168.1.0/24 tcp-flags=syn
tcp-mss=!0-1350
add action=change-mss chain=forward new-mss=1440 out-interface=pppoe-out1
passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=!0-1440
add action=mark-connection chain=prerouting disabled=yes dst-port=4569
new-connection-mark=VoIP-Conn passthrough=yes protocol=udp
add action=mark-packet chain=prerouting connection-mark=VoIP-Conn disabled=
yes new-packet-mark=VoIP-Pkt passthrough=no
add action=mark-packet chain=forward connection-mark=rtp-connection disabled=
yes new-packet-mark=RTP passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=accept chain=srcnat dst-address=192.168.0.0/24 src-address=
192.168.1.0/24
add action=dst-nat chain=dstnat comment=
"port forward openVPN port to Zentyal" dst-port=1194 protocol=udp
to-addresses=192.168.1.1 to-ports=1194
add action=dst-nat chain=dstnat disabled=yes dst-port=443 in-interface-list=
WAN protocol=tcp to-addresses=192.168.1.150 to-ports=443
add action=dst-nat chain=dstnat disabled=yes dst-port=80 in-interface-list=
WAN protocol=tcp to-addresses=192.168.1.150 to-ports=80
/ip firewall service-port
set sip disabled=yes
/ip ipsec identity
add peer=peer1
/ip ipsec policy
add dst-address=192.168.0.0/24 peer=peer1 proposal=user src-address=
192.168.1.0/24 tunnel=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.0/23,172.16.1.0/24
set ssh address=192.168.0.0/23
set api disabled=yes
set winbox address=192.168.0.0/23
set api-ssl disabled=yes
/ppp secret
add name=vpn profile=l2tp-bridge service=l2tp
add name=isipos profile=l2tp-bridge service=l2tp
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Budapest
/system ntp client
set enabled=yes primary-ntp=84.2.46.19 secondary-ntp=148.6.0.1
server-dns-names=8.8.8.8
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-limit=2048KiB file-name=rsync3.pcap memory-limit=2048KiB
