Can Anybody help!!!
I need to create a probe to get the status of “Symantec Endpoint Protection” service whether up or down.
Can Anybody help!!!
This has been documented in the Probe thread, search the dude forum for notepad.exe. As you are starting to understand on the computer you want to monitor you must enable SNMP with a community string to be able to find the programs that are running. Then you will need to create a function and a probe for your service. The probe in question was written for windows so if you are running some other OS it will need to be modified.
Lebwoski
