Title says almost all of it…
/ip/firewall/service-port> Do they cause more problems than they solve? I’m using MikroTik in a service provider environment, and I have a dedicated NAT router… it does nothing other than NAT.
I’m using src-nat, with 100.64.0.0/10, to a public IP. (I promise it’s broken up more than that, just trying to make this simple)
Question: In this environment, do the service ports hurt more than they help? Specifically the SIP helper… should I leave it enabled? Or should I disable it?
Thoughts?
