Session Time is blank question
Hi, I have mikrotik hotspot authenticating to a radius server by MAC (as user ans password). I also have user setup with only a username and password on my radius server. Everything is working fine.
The router creates a session as expected in the “Active” tab for the hotspot as expected, but session time is empty. Howe long before the session expires? When the user logs off the wifi?
Thanks, Kim
are you using Mikrotik Usermanager as your radius server or something else?
in case of something else you have to give bandwidth and duration or it can be something similar like Active hours or days. if you put the respective value then when users are logged-in you may see session time count down as well
Sent from my SM-N910C using Tapatalk
I am using a radius server. In my scenario, will the session never time-out?
