Set a Bandwidth Mikrotik Metal 2sphn
I tried to set a bandwidth limit to 1Mbps to get a symmetric link in a Mikrotik Metal 2shpn using simple queues. When i start a download test with a FTP server it shows a download rate of aprox 2 Mbps (it changes in a range of 2 - 4 Mbps), but when i do a bandwidth test with the winbox tool it shows a symmetric 1Mbps data rate behavior.
Why does this happend?
Ive tested your config and achieve the same results… anyone knows why?
I tried this as well with the same result. I was only able to get it to work over non-bridged connections.
