i want to set right time to 3 mikrotiks on my network ,i have more then 300 pppoe cliets that autenticat with AU server .
i want to know when i change the time can it take a problem for me ?
AU?..
p.s. why don’t you use NTP?..
you write big I write small xD
copy paste this to enable NTP. (Chupaka’s very nice idea.)
/system ntp client set enabled=yes mode=unicast primary-ntp=159.148.60.2 secondary-ntp=0.0.0.0
thanks for your suggest,but i want to know if i change time ,is it riskly action or not?
No.
hi
it works when i can ping for example 4.2.2.2 in my router . but if i route an ip range to a router it dose not work !!! do you have a solution for this ?
thanks for your time.
i change the time and date ,fortunately every things are good.
You can use this NTP server in all your routers ; )
