I have the initial setting (default setting of the RouterOS), of country parameter, set as “ETSI”.
I’m located in ITALY and I change it, via WEBFIG, to ITALY and set it back to ETSI; it seems that the RouterOS works either way ( I even tried other countries just to see how it reacts).
The question is: is this parameter affecting something in the use of the RouterOS, so it HAVE TO BE set with proper country ?
If I go to Slovenia or Croazia, should I change it to the country I’m in ? Is it mandatory ?
Model RBwAPGR-5HacD2HnD
Revision r3
Firmware Type ipq4000L
Current Firmware 6.49.12
Essentially there is a limit to radio emissions you are allowed to make, this has nothing to do with whether the device is connected to a LAN or not, it applies also (as an example) to Bluetooth devices.
In a nutshell, any device is limited to 100mW (20 dBm) of emission.
The most important thing in Italy is that you cannot transmit beyond your property with excessive residue,
or create point-to-point connections that cross public land or other private property not of the same starting owner (no mater the power or the scope).
(WISPs and those who can install them pay the appropriate annual license fee to the Mini$t€ro.)
So any do-it-yourself solution to connect multiple non-adhering properties is prohibited,
just as transmitting “interference” into the adjacent apartment (of another owner) is prohibited.
Furthermore, the limit is calculated for the total emitted,
so if the device has, for example, 2 polarization antennas, at most you can transmit at 50mW per antenna, i.e. 100mW total.
I would go even further, saying that noone is going to enter your house and measure the transmitting power, you should make sure to have not too much emissions outside your property.
In theory you could have all your house turned into a huge faraday cage and inside it use much higher transmission power, it would still be illegal, but you would never be caught.
But, as a matter of fact the whole thing - particularly with 5 GHz - is essentially a good thing, as it makes (should make) people having more distributed AP’s with lower power, and this usually improves the WiFi connectivity for the users.
Thanks guys,
this router is mainly used in my camper (RV) which is parked at home in the garden; despite this,
it is of great interest to me to delve deeper into the topic of “ROUTING & NETWORK”, due to my personal culture.
The network has always interested me,
on top of everything I have a level of personal knowledge “high enough” to understand the informations given to me in order to then study them further and use them (hobby).
Obviously to enter my house you must have a warrant from the Public Prosecutor’s Office,
but having said that it is known that the WiFi installed in the apartments are also visible in other apartments …
just as I see several here in my house.
Being a radio operator (IU3MLY), I am led to explore and try the technical solutions that tickle my mind.
Thanks again guys for your information, it’s invaluable.
