set field to blank
hi
i can’t speak english well but i will trying to explain
im usin API Php Class and im trying to build ppp configuration menu
when im trying to edit ppp profile im using
   $API->write('/ppp/profile/set', false);
   $API->write("=.id=$id",false);
   $API->write("=local-address=1.1.1.1",true);
it work fin
but ican’t empty the local-address field
i used
   $API->write("=local-address=",true);
   $API->write("=local-address=none",true);
   $API->write("=local-address=blank",true);
   $API->write("=local-address=disabled",true);
but nothing work
so how i can do that ??
can u use ‘unset’ ?
it works, thank you
this is the code using unset
   $API->write('/ppp/profile/unset', false);
   $API->write("=.id=*F",false);
   $API->write("=value-name=local-address",true);
may help any one
