First,
Is there a way to have a stable connection to a routerboard through mac.
I remember when the rb3011 was new, I think I could use the mac connection indefinitely.
Now after I remove the default settings I get thrown out and after that I can connect using mac.
But I can only stay connected a while and after I get thrown out again I can not connect again.
I also tried to set up a mac-server with address list “all” (i.e. all interfaces) but I experienced the same behavior as without.
Second,
I use a rb3011 and have removed the default settings.
How can I set a temporary ip to it, tried in winbox:
ip > addresses > address list > + and added 10.10.3.1/24 address on eth5 (where my pc is connected to).
I logged out and winbox identifies that address in neighbors. I tried to login with winbox using that address, but it did not work.
What should I do to make it work?
Third
Now after some time of idle I do not get anything in the neighbors tab.
Does anyone know why?
Fourth
I’m wondering if this can be the cause of a corrupted nand.
The rb3011 was hacked before, perhaps there where a lot of r/w so my nand got a little corrupt?
If so how do I reformat the nand?
