Hello.
I am trying to set the queues remotely with ssh and expect. The problem is for the set command, a print is requried in router OS. if i have more then say 20 queues, not all of them would fit on the screen, and the set command does not seem to work for items off the screen. Is their a way to set the queues without having to run the print command?
Laurence.
