Set static IP to MAC and drop another request
Hello :slight_smile:
I want Set IP and MAC with together
if user change MAC address or change IP addres traffic droped
and new user [new mac-address could not connect to my network]
my solution :
     add chain=forward src-address=!192.168.10.2 src-mac-address=001122aaf21f action=drop
     add chain=forward src-address=!192.168.10.3 src-mac-address=001122bbf21f action=drop
     add chain=forward src-address=!192.168.10.4 src-mac-address=001122fcc21f action=drop
but new MAC address device could connect to network and using internet…
Your best option is to assign static DHCP leases, and set the DHCP server to add an ARP entry, and then set the interface ARP mode to reply only. If you don’t use DHCP skip that part and add static ARP entries and set the interface ARP mode to reply only.
That way there’s no need to filter - users that weren’t mapped manually or by a static DHCP lease can’t get into the router’s ARP table, so the router can’t send any traffic to them.
tanX fewi :slight_smile:
