Hello guys. A simple question… What do you recommend me? Set up the tx-power by default or set up according to the card specification (28dbm)? (XR2 in RB 112 48v 2A)
Thanks very much, you are the best!
I suggest default, but it debpends on your antenna and the regulations in your area. Just remember the sr/xr cards have a 10 dbm difference, (you mite already know this but just in case) for example if you want to set your card to a high dmb of 26 you set it to 16, you have set it to 16 but in reality the cards output power will be 26.. There was a page that shows how it all works… I dont have the link. Thanks my 2 cents.. -Jordan
Thank you, Jordan, I don´t know that. The antenna is Hyperlink Omni 15dBi.
Please if somebody have the link post it. Regards!
http://www.ubnt.com/downloads/SRXR_power_offset.pdf The offset table, shows what i was talking to you about, The link aug provided it is in there. so be careful!
Good data, thank you guys!
