Hi, hope to get some help. I want to setup Rb Groove A-52Hpn to access internet. I have the Groove already plugged into the Mikrotik router. I can access internet using the built-in wireless and when directly connected to the RB2011 but no internet through the AP. I want to use quickset to get it working. Clearly, I am new to all this so keep the answers simple using QUICKSET. What option should I use?
Is your network schema like :
ISP → RB 2011 → RB Groove A-52 ( connected via UTP cable into one of the rb2011 lan ports, ex. port 2-10 ) ?
I understood so far :
- on your main router, rb2011, you have internet connection and if you connect wireless on rb2011 ESSID you have internet connection ;
- your Groove is still on default configuration ( most likely in router mode as shown in QuickSet window ? );
- after you plug in Groove into one of the lan ports from rb2011 and you attempt to connect wireless on Groove ESSID you receive dhcp ip address ( most likely from 192.168.88.0/24 network ) via wireless but you do not have any internet access.
Is that correct ?
If so, i am not so sure that you can make Groove as a transparent bridge as AP only with few clicks on QuickSet window. If i am wrong please someone correct me.
But still, waiting to your response in order to try to do the best to help you.
kind regards,
Yes It is.
Is that correct ?
Yes that too is correct
For some reason it just started working. And I am fine with that lol. At least for now. Thank you though.
