I am totally new to Mikrotik and I am on a quite steep learning curve…
My today’s challenge is to set up a cap AX in the best possible way.
It is behind my WAN router and I can connect to it, Internet access is working, however it is quite slow.
As a first check I used the Android “analiti” app which shows
download 19Mbit/s upload 9.5 Mbit/s for the 5GHz
download 18Mbit/s upload 8.3 Mbit/s for the 2.4GHz
Whilst measuring it I was sitting about 10ft below the cap and 2ft aside. So not far away - maybe to close?
To optimize the setup I first checked frequencies of WiFi neighborhood.
Using WEBFIG I can see 48 other WIFI Networks, some with the same SSIDs their Signals are between -64 and -97.
I expect (hope) I can ignore the weak ones under a certain level.
From what level upwards should I take them into consideration when choosing the frequency of the capAX ? Or is there a kind of "auto mode
Last question for the moment…, can I check/adjust the transmitting power? I want keep it on the minimum required to ensure coverage.
Best case I only screwed up the setup ![]()
txs for any help
# 2023-12-08 19:26:15 by RouterOS 7.12.1
# software id = XGEA-TLYF
# model = cAPGi-5HaxD2HaxD
# serial number = HEXXXXXXXXX
add admin-mac=48:A9:8A:E4:FE:BD auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] configuration.country=Germany .mode=ap .ssid=\
MCMT50 disabled=no
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Germany .mode=ap .ssid=MCMT24 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.90.10-192.168.90.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=*3
add bridge=bridge comment=defconf interface=wifi2
/interface detect-internet
set detect-interface-list=all
add address=192.168.90.1/24 comment=defconf interface=bridge network=\
192.168.90.0
/ip dhcp-client
add address=192.168.90.0/24 comment=defconf dns-server=192.168.90.1 gateway=\
192.168.90.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.90.1 comment=defconf name=router.lan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
