Hello all,
First of all, I am sorry If I used the wrong section.
I would need some help with setting Hap Lite behind existing nat network. So I have tried to set up my Hap behind an ISP provided router, well no luck..
What I want to achieve:
Since it is a shared home I would like to create my own network, in my room. (For phone, printer odroid and such…)
What I did:
I have tried to set up the Hap on automatic, and hap does not receive the IP from the first router. no luck
I tried to set it up as a static IP. no luck (I have set up the IP 192.168.1.100 255.255.255.0 192.168.1.254)
Then I have changed the internal network on the Hap to 172.16.88.1 (default IP) and 172.16.88.2- 172.16.88.254 (DCHP range). still no luck..
btw: I have been using this Hap for more than 4 years on the static IP from other ISP directly connected to the FTTH switch.
Could someone point me in the right direction?
Best,
hiper
