setting a routes 'weight' and 'distance'
It would be nice to have the ability to set dynamically learned routes weight, distance and other attributes. Possibly the same technique used for BGP (/routing filter) could be used to specify those attributes. We have cell phone and wireless connectivity that would be nice to say those default gateways (when added dynamically) can be set as a lower priority gateway and only used when the lower cost routes are invalid.
Sam
The same technique as BGP works for OSPF and RIP as well (ospf-in, ospf-out, rip-in, and rip-out chains).
I don’t know of any way to do that for dynamic-connected, or dynamic-static, though.
So, I will second this request. It would be very useful, and not just for defaults, but also for radius-learned hotspot/PPPoE/etc… routes.
–Eric
Glad to see that you implemented this, thank you!
Very cool feature, just a bit buggy (sending details to support).
–Eric
how do you do this? I don’t see this anywhere as an option. is this part of the routing test package?
Yes, it is in routing-test only.
–Eric
