I’m trying to set up a default config in devices which includes setting an admin password.
I have an rsc file which was created using /export
I’ve added the line
/user set “admin” password=“mypassword”
to the rsc file.
I do an install using netinstall and all my other settings are applied, but the password is left blank.
What am I doing wrong?
/user set [/user find name=“admin”] password=“mypassword”
This doesn’t seem to work. It works fine when logged into the device (SSH/Telnet), but not when a default config file being applied with netinstall.
Any other ideas?
Bump.
Has anyone done this as part of a netinstall configure script?
Hi. I can confirm that I have successfully used:
/user set admin password="password"
It was the last command in the script, if that makes any difference.
CD
Thanks, but was it as part of the default script loaded using netinstall - eg: the script is autorun when the router is reset to defaults?
I can get it to work in a script run at any time, but when part of the netinstall default configuration, the password is left blank
