Setting bonding mode balance-xor leading to kernel oops on CRS317
setting mode “balance-xor” on a bond triggers a kernel oops in 7.0beta8. On subsequent boots, the oops is triggered again causing the switch to halt before the boot process is completed. After I removed the SFP+ modules for the slave interfaces, I was able to boot the system again and change the configuration. Changing back to “802.3ad” caused another oops, but the system did not crash.
Booting with mode “802.3ad” works.
Version: 7.0beta8
Model: CRS317
Steps to trigger:
/interface/bonding/set 0 mode=balance-xor
Full kernel log attached:
2020-06-04 CRS317 - bonding xor.txt (30.9 KB)
Config for reference. Please note that one interface in the bond is intentionally disabled due to another bug:
2020-06-04 CRS317 - config.txt (6.63 KB)
