Setting Burstable Speed
Hi All!
Having a little problem setting the burst speed for my HotSpot. I know this is simple so just need a little help.
The documentation shows this as an example:
Rate limitation in form of rx-rate[/tx-rate] [rx-burst-rate[/tx-burst-rate] [rx-burst-threshold[/tx-burst-threshold] [rx-burst-time[/tx-burst-time] [priority] [rx-rate-min[/tx-rate-min]]]]
But, when I put that into the “rate-limit” box in Winbox it tells me it’s invalid, and yes I replaced it with actual numbers.
I’m trying to set a speed of 768k/768k and a burst speed of 1MB/1MB for 5 seconds. Can someone tell me how to enter this properly?
Screenshot of what I have in there currently and is working but is not set for burst.
Bump!
Anyone know how to set the burst speed and duration?
768k/768k 1M/1M 760k/760k 10/10
that should do it.
Similar:
768k 1M 760k 5
(if rx=tx, tx could be omitted)
Yep. I kept in the format I did because that is more clear. Just to follow the way his quote from the documentation was formatted.
Forgot to say thanks! Worked perfectly.
