Good day!
For earlier thanks for answers!
Please help in setting devices!
In the office one set CRS226-24G-2S + (192.168.1.254/16) which raised DHCP (pool 192.168.191.1-192.168.191.253 gateway 192.168.0.254)
The office is set 2 CRS125-24G-1S-2HnD (192.168.10.254/16) which raised DHCP (pool 192.168.192.1-192.168.192.253 gateway 192.168.10.254)
The switches are connected by 24 ports
That would be required using VLAN traffic was cut DHCP, but in the inside of each switch was available a DHCP
====== Office1 ======
add name=local_bridge
set [ find default-name=ether1 ] comment=LOCAL name=local01-master
set [ find default-name=ether2 ] master-port=local01-master name=local02
set [ find default-name=ether3 ] master-port=local01-master name=local03
set [ find default-name=ether4 ] master-port=local01-master name=local04
set [ find default-name=ether5 ] master-port=local01-master name=local05
set [ find default-name=ether6 ] master-port=local01-master name=local06
set [ find default-name=ether7 ] master-port=local01-master name=local07
set [ find default-name=ether8 ] master-port=local01-master name=local08
set [ find default-name=ether9 ] master-port=local01-master name=local09
set [ find default-name=ether10 ] master-port=local01-master name=local10
set [ find default-name=ether11 ] master-port=local01-master name=local11
set [ find default-name=ether12 ] master-port=local01-master name=local12
set [ find default-name=ether13 ] master-port=local01-master name=local13
set [ find default-name=ether14 ] master-port=local01-master name=local14
set [ find default-name=ether15 ] master-port=local01-master name=local15
set [ find default-name=ether16 ] master-port=local01-master name=local16
set [ find default-name=ether17 ] master-port=local01-master name=local17
set [ find default-name=ether18 ] master-port=local01-master name=local18
set [ find default-name=ether19 ] master-port=local01-master name=local19
set [ find default-name=ether20 ] master-port=local01-master name=local20
set [ find default-name=ether21 ] master-port=local01-master name=local21
set [ find default-name=ether22 ] master-port=local01-master name=local22
set [ find default-name=ether23 ] master-port=local01-master name=local23-router
set [ find default-name=ether24 ] master-port=local01-master name=local24-office2-reserve
set [ find default-name=sfp-sfpplus1 ] master-port=local01-master name=local25-sfp1-switch2
set [ find default-name=sfpplus2 ] name=local26-sfp2-office2
/ip neighbor discovery
set local01-master comment=LOCAL
add name=DHCP_pool ranges=192.168.191.1-192.168.191.254
add address-pool=DHCP_pool disabled=no interface=local_bridge lease-time=6d23h59m59s name=local_dhcp
add bridge=local_bridge interface=local01-master
set 0 dscp-based-qos-dscp-to-dscp-mapping=no
set 1 dscp-based-qos-dscp-to-dscp-mapping=no
set 2 dscp-based-qos-dscp-to-dscp-mapping=no
set 3 dscp-based-qos-dscp-to-dscp-mapping=no
set 4 dscp-based-qos-dscp-to-dscp-mapping=no
set 5 dscp-based-qos-dscp-to-dscp-mapping=no
set 6 dscp-based-qos-dscp-to-dscp-mapping=no
set 7 dscp-based-qos-dscp-to-dscp-mapping=no
set 8 dscp-based-qos-dscp-to-dscp-mapping=no
set 9 dscp-based-qos-dscp-to-dscp-mapping=no
set 10 dscp-based-qos-dscp-to-dscp-mapping=no
set 11 dscp-based-qos-dscp-to-dscp-mapping=no
set 12 dscp-based-qos-dscp-to-dscp-mapping=no
set 13 dscp-based-qos-dscp-to-dscp-mapping=no
set 14 dscp-based-qos-dscp-to-dscp-mapping=no
set 15 dscp-based-qos-dscp-to-dscp-mapping=no
set 16 dscp-based-qos-dscp-to-dscp-mapping=no
set 17 dscp-based-qos-dscp-to-dscp-mapping=no
set 18 dscp-based-qos-dscp-to-dscp-mapping=no
set 19 dscp-based-qos-dscp-to-dscp-mapping=no
set 20 dscp-based-qos-dscp-to-dscp-mapping=no
set 21 dscp-based-qos-dscp-to-dscp-mapping=no
set 22 dscp-based-qos-dscp-to-dscp-mapping=no
set 23 dscp-based-qos-dscp-to-dscp-mapping=no
set 24 dscp-based-qos-dscp-to-dscp-mapping=no
set 25 dscp-based-qos-dscp-to-dscp-mapping=no
set 26 dscp-based-qos-dscp-to-dscp-mapping=no
add address=192.168.1.254/16 comment=LOCAL interface=local_bridge network=192.168.0.0
add address=192.168.0.0/16 dns-server=
192.168.0.252,192.168.0.250,192.168.0.254 domain=novagis.local gateway=
192.168.0.254 netmask=16 ntp-server=
192.168.0.252,192.168.0.250,192.168.0.254 wins-server=
set servers=192.168.0.252,192.168.0.250,192.168.0.254,8.8.8.8,4.4.4.4
add distance=1 gateway=192.168.0.254
====== Office2 ======
add name=local-bridge
set [ find default-name=ether23 ] comment=WAN name=WLAN23-2COM
set [ find default-name=ether1 ] name=local01-master
local02-slave01
local03-slave01
local04-slave01
local05-slave01
local06-slave01
local07-slave01
local08-slave01
local09-slave01
local10-slave01
local11-slave01
local12-slave01
local13-slave01
local14-slave01
local15-slave01
local16-slave01
local17-slave01
local18-slave01
local19-slave01
local20-slave01
local21-slave01
local22-slave01
set [ find default-name=ether24 ] name=local24-Office-reserve
set [ find default-name=sfp1 ] name=local25-sfp1-Office
/interface vrrp
add disabled=yes name=vrrp1
add disabled=yes name=vrrp2 priority=254 vrid=2
/interface bonding
add comment=LOCAL mode=802.3ad name=local-bonding slaves=
local25-sfp1-Office,local24-Office-reserve transmit-hash-policy=
layer-2-and-3
add name=dhcp_pool-Office2 ranges=192.168.10.1-192.168.10.199
add address-pool=dhcp_pool-Office2 lease-time=6d23h59m59s name=DHCP-Office2
add bridge=local-bridge interface=local-bonding
add bridge=local-bridge interface=local01-master
add bridge=local-bridge interface=local26-wlan1
add address=192.168.10.254/16 interface=local-bridge network=192.168.0.0
add address=192.168.100.254 disabled=yes interface=vrrp2 network=
192.168.100.254
add address=192.168.100.253 disabled=yes interface=vrrp1 network=
192.168.100.253
192.168.0.252,192.168.0.250,8.8.8.8,4.4.4.4 domain=novagis.local gateway=
192.168.10.254 netmask=16 ntp-server=192.168.10.254 wins-server=
set servers=192.168.0.254,8.8.8.8
