Hello everyone!
I need some help to best configure 2 wans on my RB750Gr3 with routerOS 7.11.2.
This is the situation:
WAN 1 = pppoe with dynamic ip contracted by 1gpbs
WAN 2 = vlan 35 with fixed ip but only via dhcp client 1.8 gpbs contract (used only 1)
LAN = single lan
i tried to configure the router, and it works i can’t say no, if i disconnect wan1 or wan2 internet keeps working and that was the mission, BUT, internet is slow.
if i try to do speed test with both wan active the maximum download speed is 500/600mbps upload 700/800.
if i disconnect wan1 i go 950mbps if i disconnect wan2 the speed is 850/900mbps.
So I think there is something wrong with my configuration.
I am reading many posts about a similar configuration but I can’t get the speed to work right, it seems too much bandwidth loss.
I will paste the configuration here, if anyone can give me a tip I thank you!
Thank you Michele
# 2023-09-24 21:21:35 by RouterOS 7.11.2
# software id = 4IH8-5TXK
# model = RB750Gr3
# serial number = 8B00097BBA38
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment="WAN1"
set [ find default-name=ether2 ] comment="WAN2"
set [ find default-name=ether3 ] comment=SWITCH1
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=wan-digi user=\
username
/interface vlan
add interface=ether2 name=vlan-WAN2 vlan-id=35
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=WAN2
/routing table
add disabled=no fib name=to_wan1
add disabled=no fib name=to_wan2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add interface=wan-digi list=WAN
add interface=vlan-WAN2 list=WAN2
add address=10.29.22.1/24 comment=defconf interface=bridge network=10.29.22.0
/ip dhcp-client
add interface=vlan-WAN2 use-peer-dns=no use-peer-ntp=no
/ip firewall mangle
add action=mark-connection chain=output connection-mark=no-mark \
connection-state=new new-connection-mark=digi_conn out-interface=wan-digi \
passthrough=yes
connection-state=new new-connection-mark=orange_conn out-interface=\
vlan-WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=digi_conn \
new-routing-mark=to_wan1 out-interface=wan-digi passthrough=yes
add action=mark-routing chain=output connection-mark=orange_conn \
new-routing-mark=to_wan2 out-interface=vlan-WAN2 passthrough=yes
ipsec-policy=out,none out-interface=wan-digi
ipsec-policy=out,none out-interface=vlan-WAN2
add comment=test disabled=no distance=1 dst-address=8.8.8.8/32 gateway=\
wan-digi pref-src="" routing-table=main scope=10 suppress-hw-offload=no \
target-scope=10
vlan-WAN2 pref-src="" routing-table=main scope=10 suppress-hw-offload=\
no target-scope=10
I hope I’ve included everything you need
