We’re having a problem setting the egress rate on a port on the rb260gs units. When doing so it stops passing traffic on that port all together and it doesn’t work again until egress limit is removed. We also use VLAN settings but egress change is the only change that causes this problem.
Has anyone else experiences this?
I attached screenshot of settings, not VLANs 650 and 750 are not currently used on this router.
Thank you,
Thomas
