I have 3 sector antennas mANTBox 15s and 1 CCR1009. I wonder
What is the best way to set up for sectoral antennas pick up internet in CCR1009 and send via wirelles. Another doubt is whether each sector antenna has an SSID or whether I should set the same SSID on the 3 antennas.
Hi.
Is the CCR giving out DHCP to the connected clients?
Or will you do routing and run DHCP on the CPE for the internal devices?
I’m run DHCP in one RB2011 in which you receive the CPE link
