Setting Mikrotik as a Switch
I’m trying to setup a Mikrotik RB751 as a switch.
Initially I have ethernet port 2 connected to the uplink LAN and configured inside a bridge toghether with wlan1 .
When configuring ehthernet interfaces 3 and 4 as slaves of interface 2 (modifying the master-port to ethernet 2), the ping stops responding.
Setting those interfaces back to NONE, enables the ping response once again.
The interface ethernet 2 has an IP assigned wich is the one that responds to the ping.
Which would be the correct way to configure the router as a standard switch?
if you are bridging, you should set the master as the bridge not the eth2 port
also only the bridge should have an ip, none of the interfaces
