Hello
I use a cut and paste in a Terminal to config my new CPE’s
Only thing I cannot set the password without user intervention.
Both system password and auto-upgrade password.
Does anyone know how?
Hello
I don’t think it’s possible and that’s on purpose. You could use Radius authentication for users, then you paste on a standard Radius client config to the routers and passwords are only stored on the Radius server.
OK, Thanks
What happens if the radio cannot contact the radius server?
Thanks ![]()
