Setting rb411 as repeater from rb433ah
Hi there. Im running here a system using a rb433ah setting in ap mode and now i ve bought another rb411 to set up as repeater for a house that is more far away. What should i select to make this rb411 with senao EMP-8603 work as repeater? Bridge? or what? since i don t get repeater option.
Off topic. Can Cisco repeat from a routerboard?
hi,
433 as AP, 411 as station and senao as ap connected to 411.
i didn t folow your ideia.
How do i make that? senao is the mini pci on the 411 routerboard. you say to set 411 to station but how do i make that without setting all wireless to station?
thanks
aps ok!
then you send the data with 411 as station, and you can repeat the signal with a 433. The 411 has L3 license and can’t work as an AP.
And a 411a can be set as repeater from 433?
we need that you show us a map of your desired network.
It’s possible, but “the power is divided because half makes the link and half works as AP..”
