Setting time-zone-name
I am trying to set up the time and date settings on the RouterOS on a PC, but the documentation is rather incomplete. I enter the command:
system clock set time-zone-name=?
and get “TimeZoneName ::= Africa/Abidjan | Africa/ Accra | Africa/Addis_Ababa | Africa/Algiers | Africa/Asmara | …”
Ummm… I don’t live anywheres near africa. Is there a complete list of all the places that I can use?
Any help would be appreciated.
Simply find a city in that list that is in the same time zone as you. This is a pretty standard Linux setup. Winbox would be ab easier way to find your time zone.
That’s my question … what list? Where is it and how do I access it?
Forgot about Winbox. I’ve been doing all the configuring from the RouterOS command line. Let’s see … opening Winbox. There it is in “System > Clock”.
Doh!!
Well, as it turns out there aren’t any cities on the list too close by, so I entered the information manually. The manual method included the Daylight Savings Time specifics, which is non-conformist in my area.
Thanks for your help anyway.
  • Scott
Here is the list:
http://multigraph.sourceforge.net/multigraph/doc/a262.htm
I don’t understand how you could miss the list :slight_smile:
here →
EDIT: ok, so you found it :slight_smile: timezones go vertically, so for Riga for example, I can select Athens. Probably same for you.
EDIT 2: in console typing [?] will only tell you the syntax, with 5 examples. To see all available options, you need to hit [TAB][TAB]
[normis@demo.mt.lv] /system clock> set time-zone-name=
Africa/Abidjan                  America/Merida                  Atlantic/Reykjavik
Africa/Accra                    America/Mexico_City             Atlantic/South_Georgia
Africa/Addis_Ababa              America/Miquelon                Atlantic/St_Helena
Africa/Algiers                  America/Moncton                 Atlantic/Stanley
Africa/Asmara                   America/Monterrey               Australia/Adelaide
Africa/Bamako                   America/Montevideo              Australia/Brisbane
Africa/Bangui                   America/Montreal                Australia/Broken_Hill
Africa/Banjul                   America/Montserrat              Australia/Currie
Africa/Bissau                   America/Nassau                  Australia/Darwin
Africa/Blantyre                 America/New_York                Australia/Eucla
Africa/Brazzaville              America/Nipigon                 Australia/Hobart
Africa/Bujumbura                America/Nome                    Australia/Lindeman
Africa/Cairo                    America/Noronha                 Australia/Lord_Howe
Africa/Casablanca               America/North_Dakota/Center     Australia/Melbourne
Africa/Ceuta                    America/North_Dakota/New_Salem  Australia/Perth
Africa/Conakry                  America/Panama                  Australia/Sydney
Africa/Dakar                    America/Pangnirtung             CET
Africa/Dar_es_Salaam            America/Paramaribo              CST6CDT
Africa/Djibouti                 America/Phoenix                 EET
Africa/Douala                   America/Port-au-Prince          EST
Africa/El_Aaiun                 America/Port_of_Spain           EST5EDT
Africa/Freetown                 America/Porto_Velho             Europe/Amsterdam
Africa/Gaborone                 America/Puerto_Rico             Europe/Andorra
Africa/Harare                   America/Rainy_River             Europe/Athens
Africa/Johannesburg             America/Rankin_Inlet            Europe/Belgrade
Africa/Kampala                  America/Recife                  Europe/Berlin
Africa/Khartoum                 America/Regina                  Europe/Bratislava
Africa/Kigali                   America/Resolute                Europe/Brussels
Africa/Kinshasa                 America/Rio_Branco              Europe/Bucharest
Africa/Lagos                    America/Santiago                Europe/Budapest
<######  I have removed most of the list to save space #######>
Ahhh! The old “tab tab” trick! Missed it by THAT MUCH!! :wink:
I missed the list because I was not using Winbox on a Windows PC. I was using the command line interface on the RouterOS, But once I used Winbox, I saw the list.
like I said, tab-tab would show you the list also in command line.
After rebooting the mikrotik, time configuration is not staying at previous setup. Would you please help to add time zone website in mikrotik so that time do not change and router can synchronize time?
RouterBOARDs don’t have a battery, so time will be reset after reboot. Use NTP to get time from the internet (or a locally situated NTP server). You can read more about it here:
http://wiki.mikrotik.com/wiki/Manual:System/Time#SNTP_client
