Dear All,
I’m newbie on mikrotik I buy xr5 and rb333 but at tx power when i set card rates and set 28dbm i see 28(18) is this mean actual tx power set to 18dbm or what? tnx for you help
Dear All,
Yeah you right, if you see in the TX Power 28 this is the current power but you are force your card, and i recommend you try with DEFAULT and make a test if this work then let it else try increment the TX Power to 20, 24, 26.
When you uses the Max power reduce the time life of your card.
Best regard
